Basemaps unavailable after upgrading to 11.2
2195
21
04-23-2024 04:55 AM
ShelbyZelonisRoberson
Hello,
I recently upgraded my ArcGIS Enterprise 10.9.1 to 11.2. It is a single machine deployment. Since the upgrade, our basemaps are unavailable in both Pro and the map viewer in Portal. When clicking on the basemap options we get a screen that says "Basemaps unavailable".
I've checked all of the organization settings - the basemap gallery is set to default, and nothing was changed after the upgrade.
I have a ticket out with Esri. They said to try to re-index the Portal, even though the index counts currently show no issues. I'm going to do this later today, but I'm skeptical it will make a difference. I was wondering if anyone else is having a similar problem? Any other suggestions?
Thanks!
Now that you guys mention it, we got that languages error also.
I upgraded a month ago and have created a lot of content since then. I can't revert back to a snapshot from pre-upgrade. Esri needs to provide a solution for us.
DavidColey
Honored Contributor
Yes I am still working through this issue with support, and as noted above by @StevePoladian, our latest search of the postgres gwdb for
-c "SELECT username FROM gw_users WHERE username LIKE '%esri%'"
returns
esri_apps
esri_solutions
esri
esri_livingatlas
esri_demographics
esri_boundaries
Support just suggested that the return for this query should have shown:
"Based on the what languages the user has disabled at Portal Admin, we should not expect the following users to be returned:
  • Bulgarian - Български - bg (false)
  • Catalan - Català - ca (false)
  • Hungarian - Magyar - hu (false)
  • Slovak - Slovenčina - sk (false)
  • Slovenian - Slovenščina - sl (false)
  • Ukrainian - Україна - ukr (false)"
Which are the languages portal has disabled by default.
Perhaps support meant for me to perform a query for languages?  Are languages in fact usernames?  I don't know, but to me this doesn't follow.
I replied to support and we'll see what's next, but they are suggesting that through Portal Admin I disable the English language and then re-enable, with the thought being that by re-enabling the English language that will bring back or re-sync missing or mis-directed content.  I've never done this so I am not going to attempt this just yet - I don't know how Portal will be affected
@ThomasColson
@ShelbyZelonisRoberson
DavidColey
Honored Contributor
I am happy to report that there is a solution to this!  In working with support last night we were able to perform certain queries and updates to certain tables contained in the the portal gwdb, all via the postgres command line interface.
The updates will remove and then add languages, and upon completion of the workflow, the English language pack is fully available, thus enabling (for us) the Instant Apps template and config pages, as well as restoring Map Viewer Symbol symbol categories.  I cannot speak to a re-gain of the Esri Basemaps content as we did not lose that part first reported here by @ShelbyZelonisRoberson
I am not able to relay what we did exactly, but anyone affected by this should be able to work with their support analyst now to affect this repair.
Support cannot yet say whether the fix will be included as a patch for 11.2 now or as part of the 11.3 release (or both) - they just don't know yet.
FYI the Instant App issue for the Sidebar app does still exist, where the 'Sidebar' has become a "Footer' and the Filter tool is non-functional, and some other css issues, so looking forward to 11.3 for this fix, @KellyHutchins
@ThomasColson
@StevePoladian
TimoT
Hi @DavidColey
I've run into this same problem post 11.1 to 11.3 upgrade. Are you able to share any additional information about the workflow used to resolve your instant apps issue? Can you provide your Esri ticket number for reference?
DavidColey
Honored Contributor
Hey not sure where you guys are with this but if you look at may last post here:
https://community.esri.com/t5/arcgis-enterprise-questions/arcgis-enterprise-11-3-vs-11-1-portal-web-...
the upgrade from 11.2 to 11.3 went very well.  I was able to convince my security team to allow me to disable active virus scanning during the setup exe and post upgrade steps for all the components, and wa-la, what used to take hours and hours per server completed in 15 - 30 minutes, with Portal taking like 20 minutes, Server taking around 25- 30, and datastores like 15 minutes.  Small hiccup with the reinstall of the Federated Site WA
@StevePoladian
@ThomasColson
Nice!!! Esri tech support told me not to upgrade to 11.3 until they get the 11.2 issue figured out. They said to go ahead for you?
DavidColey
Honored Contributor
Yes it was a big relief to have things go quickly for the first time that's for sure...  Not really, but since support and I came up with the adhoc fix, I was in the clear to go ahead with the upgrade.
I can only guess that since you lost basemap content as well as Instant apps, that maybe your fix is more complicated - and so they haven't come up with a fix in your case?
Nope! They only logged it as a bug. Hope I get a resolution soon because it’s been a real pain.
DavidColey
Honored Contributor
jeez  . . . well they're aware that's for sure....
DavidColey
Honored Contributor
Hi @TimoT - everything I had done related to this trouble is posted here and in my related post, with the the link to that post on page one of this post. My related post also has my case number.
