Arcmap 10.2.1 - How to automatically set portal connection on startup
3956
6
09-23-2014 12:49 PM
MikeWelch
New Contributor II
Greetings,
Most users at my company are not administrators of their own machines so they cannot run the ArcGIS Administrator tool, click on Advanced and then Manage Portal Connections to add the connection to our site on ArcGIS.com (ex: http://my_company.maps.arcgis.com). Any know of a way to do this programmatically for any user that uses ArcMap for a given machine or possibly on installation of 10.2.1 desktop?
I tried the route of setting the following registry keys when ArcMap is installed, but they are only for the current user; new users will not have them set:
HKEY_CURRENT_USER\Software\ESRI\ArcGIS Online\SignIn\URL0 set to value: "http://my_company.maps.arcgis.com"
HKEY_CURRENT_USER\Software\ESRI\ArcGIS Online\Portals String\HomeServerURIFile set to value: "http://my_company.maps.arcgis.com/arcgisuris.xml"
Thanks in advance for any help you might be able to provide,
Mike
MarkBockenhauer
Mike,
On a 64 bit machine it need to go here:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ESRI\ArcGIS Online\SignIn
and the key is "HomeServerURIFile"="https://portal/name/arcgisuris.xml"
for example:
I forgot about the part.
Mark
MikeWelch
New Contributor II
I created a support ticket and after working with the support analyst he created an enhancement request with this being an issue (ENH-000082222)
MarkBockenhauer
Mike,
Not sure if this will work.
Assuming your registry entries work for the current user.
Try putting the registry entries at HKEY_LOCAL_MACHINE\Software\Esri
ArcMap might pick up the settings from this location if they exist.  ArcGIS Explorer Desktop allows for deployment this way, and ArcMap may employ a similar strategy.
Mark
MikeWelch
New Contributor II
Mark,
Thanks for responding to my query, would the key/strings be:
HKEY_CURRENT_Machine\Software\ESRI\ArcGIS Online\SignIn\URL0
HKEY_CURRENT_Machine\Software\ESRI\ArcGIS Online\Portals String\HomeServerURIFile
I tried these, but they were not picked up by the user.
Mike
MikeWelch
New Contributor II
Sorry, my cut and paste skills failed above:
HKEY_CURRENT_Machine\Software\ESRI\ArcGIS Online\Portals\HomeServerURIFile
URL0 and HomeServerURIFile are strings.
MarkBockenhauer
Mike,
for example:
Mark
MikeWelch
New Contributor II
Mark - thanks for your help with this. ESRI said they are looking to address this, but your solution above is the best solution for now.
Mike
