ArcInfo Generate File to Shapefile
654
08-22-2012 11:55 AM
MarkWhite1
Back in the days of ArcvView 3.1 someone (Ron Wardenier) wrote an Avenue script that would convert an ArcInfo Generate file to a shape file. Can this function be done in ArcView 9.3 (Standard) or is there a script for ArcView 9.3 (Standard) that will accomplish this function?
(Hopfully this is the correct forum for this question)
Thank you
MelitaKennedy
Esri Notable Contributor
Possibly this script:
ET Generate 3.0
I'm not sure which version it was written for.
Melita
MarkWhite1
Hi Melita,
The script you attached worked for ArcView 9.3. Thank you for your quick reply and the script.
Have a Wonderful Day.
