ArcGIS Portal "whoami.exe"
2586
05-17-2022 06:43 AM
Labels (2)
BernardMurphy
ArcGIS portal logs an instance of "whoami.exe" in the security event log every minute or so. Security team are picking up on this as unusual activity. Is this normal behaviour by design and if so what is its purpose ?
ReeseFacendini
Esri Alum
That is by design, and it happens because Portal is checking that the ArcGIS Process owner can read / write to the required directories (db, temp, content, index).
