ArcGIS Portal - Not selection outline on published subtype group layers
397
12-10-2024 12:44 PM
dpsaltis
Dear Community,
Publishing a Subtype Group Layer to Portal, results in the following bugs:
1. The layer is selectable, but no selection outline or fill is rendered. Tried many different ways for a workarount but couldnt find. Applies either on simple maps and apps.
2. Subtypes description is not available. (have to create an extra field with arcade and call the subtypename function).
3. Can't change symbology. if something changes to data categories i have to overwrite the feature layer, then remove and add the feature layer from the map, which results in loosing every modification done.
4.  Can't create custom labels.
5. Domains descriprion is not available. Only Codes.
ArcGIS Enterprise 10.2
