ArcGIS Enterprise 11.0: Why the sharing url fails to access content items,
313
10-26-2022 01:25 AM
JamalNUMAN
Legendary Contributor
As per the screenshot below, it’s requested to provide sharing url below. However, when accessing this url, it ends up with message in red.
https://jamalnuman3/portal/sharing/content/item
It manages to access the portal via adaptor with the link below
https://jamalnuman3/portal/home/content.html?view=table&sortOrder=desc&sortField=modified&folder=jam...
What could be the issue here?
Jamal Numan
Scott_Tansley
MVP Regular Contributor
Instead of using:
try:
https://jamalnuman3/portal/sharing/rest/content/item
the link you’re using was deprecated several versions ago and the error message states to insert the ‘rest/‘ component into the URL instead.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
