ArcGIS Enterprise 11.0\ Pro 3.0.2: Why “data store” registered by portal can’t be unregistered?
550
10-05-2022 09:35 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why “data store” registered by portal can’t be unregistered
Jamal Numan
ReeseFacendini
You need to log into the Enterprise Portal as the user that created that DataStore connection, go into the item details, Settings, and down at the bottom of the Settings page, uncheck the box for the connected server. Once the DataStore is no longer connected to ArcGIS Server, it can be removed via Enterprise Portal.
Only DataStores added through the ArcGIS Server Manager can be removed through the Server Manager. All other DataStores need to be removed through the Enterprise Portal
MariaThors
I have the same problem, but the checkmark is grayed out. Status says "Not Available". The database does not exist any longer, I need to unregister the connection...
MariaThors
Found out how to do it, from Pro.
JamalNUMAN
Not sure how can I go to “item” detail in the the screenshot below
Jamal Numan
