ArcGIS 9.3 & 10 export to illustrator - compound shape problems
699
02-15-2011 02:31 PM
AndyRitchie
I have a bunch of polygons in a geodatabase that are not overlapping (geology polygons). I have attached an image where the left side is Adobe Illustrator (CS4 or 5 - they both do the same thing) and the right side is ArcGIS (9.3 or 10 - also both do the same thing).
I am running into a problem on export where a large polygon with many voids (gray in right side of attached image) loses the ability to properly mask to display other polygons/voids that it surrounds (gray and brown).
I think this has to do with the number of internal polygons in the large polygon/compound shape, because it doesn't always happen based on the extent I export. Also it doesn't  happen if I export to PDF and open in illustrator (but then there are no layers).
Anyone have any ideas?
847396730
Occasional Contributor III
Are you releasing the clipping mask once you get into Illustrator?
AndyRitchie
Yes. I typically select and delete all of the clipping masks as soon as I open in illustrator.
The PDF export is an OK workaround, but less layer information is preserved (they stay grouped, but not named, and I don't think that subgroups persist).
Again, I think the issue is related to the complexity of the exported polygon layer. If I zoom in past a threshold, all polygons are properly represented. out beyond that threshold, some polygons become compound shapes with the same color as the larger (more vertices) polygon.
Hello! I bet by now you've found a workaround, but thought I'd pass along that Arc misbehaves during Illustrator export if Group Layers are involved.  I had some frustrating issues that were resolved upon ungrouping in Arc and repeating the export.
