Address Locator Issue-US Single House Addresses
1473
05-09-2017 10:07 PM
user1portal
I have created an address locator with the address style "US Single House Addresses" to use in the search widget of Portal for ArcGIS. After publishing the locator as a geocode service i used this service to configure the Search widget.
After configuring the tool working in a weird way. If i enter a street name like 'Smith Street' i is showing auto suggestions like '10 Smith Street,11 Smith Street" even though there is no address number in that particular street name.
This suggestion method is misleading the users and casuse me alot of headache.
Anyone please suggest a solution for the issue.
ShanaBritt
If you are going to be searching for street names and street addresses, you may want to consider creating a locator based on the  US Address - Street Name style, then adding it to a composite locator as the first locator along with the Single House locator. Publish the composite locator as a geocode service.
The suggestion behavior you encountered is a known issue that we are working to address. More details can be found in the final response in the following thread, https://community.esri.com/thread/181310#comment-716581 .
-Shana
