Add Item By URL - WFS with Custom Parameters
181
a week ago
GISP00
Using ArcGIS Portal 11.5 I am trying to add a layer to a web map using a URL that is a WFS service type. If I paste the full URL in a new web browser tab it it works. But when I try use the Add Item By URL option and the custom parameters, the error is service does not exist or is inaccessible.
Screenshots attached to help convey the problem and settings.
Opinions and advice are my own and not the views of my employer.
This is my personal account. I am not acting as an agent for my employer.
TimoT
Is the WFS publicly accessible or secured?
Given that the WFS XML loads directly in the browser, the next most common causes of this error in my experience are:
1. Cross-Origin Resource Sharing (CORS) issues
Open your browser’s developer tools (hotkey F12), reproduce the error, and check the console tab for CORS-related messages. Sample reference image below:
If you see this type of error, you'll likely need the WFS host to whitelist your domain.
2. TLS handshake/validation errors
These types of errors can vary, and diagnosing them is challenging without full URL details that have been sanitized in your images. To check for issues of this nature:
  • Have you configured your Portal to restrict the proxy capability?
  • Log into the Portal Directory (/portal/sharing/rest) and navigate to Home > Portals > checkUrl. Enter your WFS URL, and if it returns anything other than a 200 status response, it could indicate that your Portal can’t verify the TLS certificate. If this is the case, return with more info/screenshots and we can investigate next steps further.
