Add AGOL Service to Portal for AcrGIS - Store the credentials
5622
16
04-05-2017 06:34 AM
GISMountains
Hi all
I would like to add a 3D-Service which i published to ArcGIS Online in Portal for ArcGIS. Because it is not a public service i need to input the credentials.
If I insert it to a webmap I need to input the credentials every time? Is there a way to store them in Portal for ArcGIS?
Cheers
Stefan_Arndt
I do receive the same error message as Jake in my environment.
It seems to be a problem with the proxy, which is a proxy with authentication.
Even if the service account user of portal is allowed to access the internet via proxy, it does not work correctly.
ChrisGreen6
Hi Stefan
Did you ever find a solution for this? I am trying to view some AGOL layers in Portal and do not want to share them publicly.
LakshmananVenkatesan
Hi Chris
I am facing same issue, do you have a clue?
Lakshmanan
ChrisGreen6
Unfortunately I do not.
AlexChiu2
I'm also looking for a fix for this exact issue. Any updates from Esri?
TomDe_Leus1
Did anyone solve this problem. I'm having the same issue ....
AlexChiu2
The error message is extremely confusing and does not provide any guidance as to what the underlying issue is.
To troubleshoot this I had to reproduce this issue with the browser dev tools open and inspect each response of the network calls manually. There I was able to see some errors around proxy authentication issues.
From there we configured our Portal server to go through our proxy server for server side calls, see - Configure your portal to use a forward proxy server—Portal for ArcGIS | Documentation for ArcGIS Ent...
I also had to work closely with our network infrastructure team to to make sure that the domains of the AGS services we were trying to use were whitelisted on the proxy server too. Hope this helps.
