Monitoring ArcGIS Server using Azure Monitor etc
2464
10-13-2020 02:09 AM
JohnFannon
Hi
We are looking to monitor ArcGIS Server (v10.7.1) on Azure using some of the built in Azure Monitor capabilities (e.g. Log Analytics, Alerts, Application Insights).
I've been looking at ingesting the ArcGIS Server logs and trying to follow what's in the following Esri presentation, but our ArcGIS Server was not installed with cloud builder and has logs that are in xml format, not csv format as describe in the presentation.
ArcGIS Enterprise: Cloud Operations using Microsoft Azure
So questions are:
1) Is it possible to ingest traditional xml-based server logs using Log Analytics?
2) Is it possible to change the ArcGIS Server logging to csv - how is cloud builder different?
3) Does anyone have any other advice/recommendations regarding monitoring ArcGIS Server in Azure?
Any assistance much appreciated, as there seems to be a disconnect between the Microsoft Azure documentation and what is possible with ArcGIS Server.
parksh
Hi @JohnFannon
Did you find solutions?
JohnFannon
Hi @parksh - no we didn't. However, we are just starting to look at this again in more detail in the coming months, so will post any findings here.
HeatherM_JDI
Did you get this working? We are interested in the same!
