Azure Application Gateway V2 by default is set to standard of WAF mode?
1885
01-11-2022 09:30 AM
DiegoLlamasOlivares
Hello,
I have a question, Using ArcGIS Enterprise CloudBuilder for Azure, i can create a new Application gateway, When I use Cloudbuilder I cannot set this as standard or WAF or Can I set that option for Application Gateway?
Diego Llamas
ChristopherPawlyszyn
By default the Application Gateway will use the Standard V2 tier, but admins have the ability to upgrade to the WAF V2 tier in the Azure portal once the deployment is completed.
-- Chris Pawlyszyn
-- Chris Pawlyszyn
