The coordinates widget is not fully visible on an i-phone and therefore you can not request coordinates by placing a marker on the map. The coordinates widget on an I-pad contains, at the far left of the depicted coordinates, a 'cross'. If you tap this and you place a marker on the map you will get back the coordinates of the marker. On an I-phone there is no functionality to place a marker on the map and get back the coordinates.
