The Review Sharing menu doesn't describe what will be updated
378
11-04-2025 07:51 AM
Status: Open
OttoDiveley
When managing sharing levels on items in Enterprise, if there is a difference in sharing level between items, it will ask you to synchronize the sharing levels. This is a good feature, but sometimes the different levels are intended, and unilateral synchronization isn't useful. When reading through the dialog about what is being synchronized, there isn't visible information about What Will Be Changed, or the end effects. Only what the current setting is. This assumes that the user is aware of the change that they're making and how they want to apply it, which can end up causing users to apply changes to items that didn't need to be updated, or applying incorrect changes to items that were intended to be shared a specific way.
It would be great to get an extra box in the review sharing menu like below that helps differentiate the change being made to the sharing level. Currently, making a lot of different sharing level changes in a day requires lots of attention to this.
Below is an edited example of updating sharing level from Organization to Owner, and potential implementation
