Responsive design/update for ArcGIS Monitor
299
05-03-2019 08:34 AM
DEWright_CA
Occasional Contributor III
The current version of ArcGIS Monitor does not work well in a vertical context monitor; in the case where you have a 20"/24" wide-angle monitor:
Vertical Monitor Dashboard
but have it vertical and have the monitor vertical then the navigation at the top becomes inconsistent; and access to the content area gets blocked by the obscured navigation. Now when you try to access content areas such as the ArcGIS Block:
Vertical Monitor ArcGIS Section
Now you will need the top navigation is gone; the menus have shifted below and the ability to expand/navigate the content tree in the left panel is lost.
1 Comment
GeoJen
by Esri Contributor
Hi @DEWright_CA ,
Can you please update to the latest version of Monitor and revaluate if your use case is met?
Jen
