Dear ESRI Team,
I am reaching out to share an idea that aims to improve the functionality of ArcGIS Server by incorporating a feature to limit the maximum size of geodatabase uploads. This enhancement would offer users/administrators greater control over the size of data they can upload to the server, ensuring optimal performance and efficient data management.
Problem Statement: Currently, ArcGIS Server allows users to upload geodatabases of any size, which can occasionally lead to performance issues, prolonged processing times, and potential resource constraints. With the increasing size and complexity of geodatabases, it is becoming essential to implement measures that prevent large, unwieldy uploads, and promote a more streamlined data management process.
Proposal: Introducing a feature within ArcGIS Server that allows administrators to set a maximum geodatabase upload size would offer numerous benefits to both the system administrators and end-users.
Benefits:
Thank you for considering this proposal.
Best regards,
Daniel
