In a web map, when you add a hosted feature layer or a map service the following icons appear (on mouse hover) under their content pane entry:
An image service only has:
It would be beneficial to the user experience if this was standardised somewhat - or at least be configurable. We had a user request for "image display" to pop up by default so that it is highlighted to end users as a capability.
