Determining concurrent users from AGS Monitor/Portal
987
07-21-2020 02:36 AM
AnjulPandey
New Contributor III
Provision to get concurrent users report for past duration from ArcGIS Monitor. Usage, performance report of server response time based on number of concurrent user.
Also we need to report on concurrent users currently logged into enterprise portal.
3 Comments
GeoJen
by Esri Contributor
Hi @AnjulPandey
In Monitor 2023 if you register Portal as a component you will see a metric called "Users - active" which reports the number of users who have logged in within the last 30 days. Does this solve your use case? If not what other information would you need?
AnjulPandey
@GeoJen
 I have checked and the same information is available in the portal itself. There are no further enhancement/changes in ArcGIS Monitor 2023 or Enterprise portal.
I am looking below information as mentioned earlier-
  1. Looking provision to get concurrent users report for past duration from ArcGIS Monitor.
  2. Usage, performance report of server response time based on number of concurrent user.
  3. It is possible to view users who are concurrently logged into enterprise portal.
GeoJosh
