Support for Pre-Authentication with Azure Active Directory (AAD) when using Azure Application Proxy with ArcGIS Enterprise is highly needed in order to provide secure access to ArcGIS Applications in our organization without depending on VPN-solutions. As of now, only passthrough pre authentication is supported with AGE, and this doesn’t allow us to use Conditional Access Policies, SSO and two-step verification.
