Work with Microsoft to allow ArcGIS Map Services to be used in SQL Server Reporting Services. SQL Server Reporting Services supports integrating maps, but it is very limited. Using our enterpise map services in SSRS would be beneficial and assist many in our organization.
Hi Eric, thank you for pointing this idea out here. If a component such as a Reporting Service was not available, how would you envision web services to interact with SSPS? Looking into their documentation, it says it reads from a shapefile, but does the product support web services?
