Unable to Create an ImageService SOE
1570
03-08-2023 02:41 PM
MassimilianoGeppi
Hi guys
I'm trying to create a SOE for an Image Service but when i configure
[ServerObjectExtension("ImageService" ... ] attribute i receive a System.Exception that say
... ImageService specified in class attributed is invalid. Allowed Values MapServer.
Seams that with ArcGIS Enterprise SDK is possible to made SOE per MapServer only.
Is it really so?
m
MassimilianoGeppi
Hello everyone, it's now possible to compile a SOE/SOI for image service.
It was a bug repaired from ArcGIS Enterprise SDK 11.2 version.
m
nicogis
from help it seems so
MassimilianoGeppi
from another help seems to be possible create SOE for ImageService ... which is the true?
Server object extensions
SOEs are appropriate if you want to create service operations to extend the base functionality of map and image services (including map and image service extensions, such as feature services). They provide the following advantages:
from -> about-extending-services.htm
nicogis
Hi Max, it depends where the sentence is written if in arcobjects or sdk context since up to 10.9.1 you can also use arcobjects where you can develop for images services
MassimilianoGeppi
m
