Viewing SPK files in ArcGIS Earth
5674
8
07-16-2016 09:34 AM
YigalMuntner
Got the new ArcGIS Earth 1.2.1. I'm trying to load 2 SPK files that were create by Bentley's Context Capture (mesh), But I get: 'Unknown error occured'. If I load the same SPK file to ArcGIS Online, everything is OK and I can see the mesh. How can I use these files in ArcGIS Earth? See the attached screen shots.
Yigal
DanPatterson_Retired
from your images, I can't tell whether your settings and file coordinate systems match or enough information to make a match... this is a reference from the help files
  • Spatial Reference (restart required)ArcGIS Earth always displays data in the WGS84 Global Coordinate System. Web Mercator is used as the default spatial reference for incoming Esri REST services. If you want to view service-based data in the WGS84 coordinate system, you'll need to change the spatial reference setting and restart ArcGIS Earth.
YigalMuntner
Dan,
I'm not talking about a service. I'm talking about loading an  SPK file from my computer to ArcGIS Earth, which does not work.
Loading the SPK to ArcGIS Online was ok. A scene service was created and I was able to load the service to ArcGIS Earth. The data is WGS84.
Yigal
The last time I heard, development was going to be directed to getting more formats brought online... before UC
perhaps Chris Andrews might have more info.  see Jasmine's Jasmine Du  comment https://community.esri.com/message/608609#comment-608609
XuewenZhang
Hi Yigal,
The SPK should work in ArcGIS Earth V1.2.1. Could you share your SPK to us to debug the issue?
Xuewen
by Anonymous User
Not applicable
Hi folks,
Just today,  I discovered that Bentley has a minor issue with their SPK files. I've let them know.  The way to get them to work is:
1. Use 7ZIP to unzip the file (it will take a few minutes if its very large) into a folder
2. Go into that folder and select all the items and use 7ZIP to add the items to a new archive.  Make sure to set the compression level to “Store.” (This means there will be zero compression.)
3. Rename the file to change .zip to .spk
From there, it works fine locally in Earth.
Thanks, Chris
1.      Use 7ZIP to unzip the file (it will take a few minutes) into a folder
2.      Go into that folder and select all the items and use 7ZIP to add the items to an archive.  Make sure to set the compression level to “Store.”
AitorCalero_García
Hi Xuewen, I have the exact same problem with an SPK file. It does not load in Earth and it shows an unknow error.
See screenshot below:
XuewenZhang
Hi Aitor,
Maybe you can try Chris' method. It works for me.
If you still can't add it in ArcGIS Earth, could you share your SPK for us to debug the issue?
Xuewen
YigalMuntner
I managed to view the file in ArcGIS Earth using this scenario. The problem is that now I could not publish the SPK to my AGOL subscription, and got an error loading the scene layer to the web scene.
