Terrain Basemap in ArcGIS Earth
847
03-01-2021 09:53 AM
Nomikos_Nikolaos
Hello to everyone. I use the ArcGIS Earth mobile app for Android. I cannot import an img file (DEM) as terrain in order to view my basemaps in 3D  form like the same application in  Windows.
Can anyone help? Thank you very much for your patience.
Bing_AnChen
Hi Nomikos,
You mentioned 'the same application in Windows', do you mean ArcGIS Earth Desktop? A more specific description of your workflow would be helpful for us to give the best solution.
Currently ArcGIS Earth Mobile use the basemap service aligned with user's portal, ArcGIS Online as default. If you want to use your DEM file as basemap/terrains, consider sharing within a map package in ArcGIS Pro. Thus you would be able to add this MLPK to Earth Mobile and free to use even offline. See the link layer-package in ArcGIS Pro  to see if that helps.
Feel free to contact Earth Team if there's any further information.
Best,
Bing'An
Nomikos_Nikolaos
Thank you very much for your help.
I mean that in ArcGIS Earth Desktop, the user has the capability to add a local DEM file as Terrain and view the basemap as 3D.I will try your proposal.
Best,
Nomikos Nikos
