No "Labeling" option in layer's context menu
2569
04-18-2023 10:24 AM
Katie_Godding
I have ArcGIS Earth 1.14.
I'm interested in adding labels to some features.
According to this: https://doc.arcgis.com/en/arcgis-earth/use/apply-label.htm you should be able to add labels to Shapefiles, .txt and .csv files, GeoJSON, and Feature services. However, when I try to follow the following steps from that site for a shapefile or feature service I've added to ArcGIS Earth:
I don't see the Labeling option. I see the same icon but it says "Symbology":
and there is no secondary menu to turn on label visibility.
Am I missing something?
I've also attached the screenshots.
chengfang-dong
Yes, labeling settings are supported starting from Earth v1.15:
What's new in ArcGIS Earth 1.15—ArcGIS Earth | Documentation
Pål_Herman_Sund
With the Shapefile I am testing.. everything is according to the doc, Earth 1.16
chengfang-dong
jsphillips
Hi @Katie_Godding are you able to download and install the latest version of ArcGIS Earth (v1.18)?
John Phillips | Product Manager ArcGIS Earth
Esri | jphillips@esri.com | T 757 575 0786
Katie_Godding
Hi John,
Yes, downloading and installing ArcGIS Earth v1.18 did the trick.
Thanks!
jsphillips
Awesome!
