<linkName>, <linkSnippet>, and <linkDescription> of the KML <NetworkLinkControl> are not refreshed in the Data window
Only the initial <NetworkLink> <name>, <Snippet>, and <description> are displayed.
Note that the NetworkLinkControl items are correctly refreshed in the data itself. For example, when the network link is clicked in the Data window, we can see that the description is updated.
And if the network link is right-clicked and saved from the Data window, we can see the updated information in the KMZ file.
However, none of it is refreshed in the ArcGIS Earth Data window.
Hi @BillClark
Thank you for reporting the issues. We will try to fix it in the upcoming (this November) release of Earth 1.14.
Best,
Yongwei
Thank you, Hope this is still on the list. It apparently did not make it into 1.14
Best regards,
Bill
Hi @BillClark ,
Thanks for reaching out to us regarding this issue.
Definitely, I'm glad to share that the NetworkLinkControl items have been already supported since ArcGIS Earth 1.14. Currently, we just released 1.15, this feature is supported at both versions.
I tested via my data with NetworkLinkControl, and found the items can be refreshed expectedly.
Would you mind if you share the testing data and the steps to us, with which you encountered this failure ? Screenshots will also help.
so I can do deeper testing on this issue to investigate whether data specific issue or software defect.
Please feel free to send email to ArcGISEarth_Feedback <ArcGISEarth_Feedback@esri.com>
Looking forward to your feedback ! 🙂
Best,
Sharon
Hi @BillClark ,
How is going ? Shall we connect via email ?
Please feel free to send email to ArcGISEarth_Feedback <ArcGISEarth_Feedback@esri.com> , and we'll assit you on this issue.
Thank you !
Xiaoyan(Sharon) MU
As of version 2.2 <linkName>, <linkSnippet>, and <linkDescription> are still not updated. Also, while a different topic, complex css styles in names and snippets are not supported. For example,
<?xml version="1.0" encoding="UTF-8"?>
<kml xmlns="http://www.opengis.net/kml/2.2" xmlns:gx="http://www.google.com/kml/ext/2.2" xmlns:kml="http://www.opengis.net/kml/2.2" xmlns:atom="http://www.w3.org/2005/Atom">
<Folder>
<name><![CDATA[<span style='color: magenta; text-decoration: none; font-weight: bold; font-family: Georgia;'>Name - Magenta</span>]]></name>
<Snippet maxLines='1'><![CDATA[<span style='color: darkorange; text-decoration: none; font-weight: bold;'>Snippet - DarkOrange</span>]]></Snippet>
<visibility>0</visibility>
</Folder>
</kml>
Thanks @BillClark for the feedback.
We'll bring the testing data back for deep-dive testing and keep you updated.
Not sure if you have tried the linkName, linkSnippet, and linkDescription in KML Spec 2.1 on your side?
Please feel free to let us know if any questions.
Thank you again.
Sharon
Hello,
Still not working. I just tested "ArcGIS Earth 2.3 Early Adopter".
linkName, linkSnippet, and linkDescription are not refreshed.
styled <span> tags are not supported in names or snippets (see above)
Hi @BillClark,
Thanks for the prompt feedback of the Early Adopter version 2.3!
I double checked on my end, and find currently refresh of `<linkName>`, `<linkSnippet>`, and `<linkDescription>` are actually supported by ArcGIS Earth. As you may have found, it supports pure Text String only so far, the rich style is just ignored.
See the example as following:
The name of the network link node is changed from "Not Changed" to "Name Changed!" after refreshed.
From the KML coding aspect:
In ArcGIS Earth, Table of Content (TOC) is designed to be concise and consistent across all kinds of data layers. ArcGIS Earth is able to consume various data types including KML.
If a rich style of KML layer names in TOC is a priority for your work, please free free to share your requirements with us. We will do our best to accommodate them.
Which kind of styles are the most frequent used? from the KML coding your provided earlier, I found it like font style, font color, etc. any style more?
Sharon
Hi @BillClark , it's been a while since we last connected. I'm delight to share some updates on this topic.
In the coming ArcGIS Earth V2.4, the complex style of KML Name, Snippet, Description, linkName, linkSnippet, and linkDescription are fully supported. This means ArcGIS Earth will now honor these predefined styles directly in the Table of Contents (TOC).
I’ve included a screenshot of a few testing examples from my side for reference — just to give you a quick preview. Stay tuned for the new version!
