Can we set autostart to true by default
287
10-25-2021 04:23 PM
BillSmith
Can we change the default setting to true for autostart?
I'm having to modify the file after it is copied into the user directory and set it to true.
copy
C:\Program Files\ArcGIS\Earth\bin\automation\settings.json   to
C:\\Users\\<user.name>\\Documents\\ArcGISEarth\\automation\\settings.json
Modify the autostart setting to true, it is false by default.
Install dir file.
"version": "1.12",
"autoStart": false,
"baseUrl": "http://localhost:8000"
After copy to user dir
"version": "1.12",
"autoStart": true,
Pain in the **bleep**!!!
LexieLi
Hi @BillSmith
Thanks for your feedback.
Currently, our default setting is true and supports editing the settings.json in <user.name>\Documents\ArcGISEarth\automation.
We have logged your great suggestions and will improve this in the following releases. We will also keep you updated.
Lexie
