Can we change the default setting to true for autostart?
I'm having to modify the file after it is copied into the user directory and set it to true.
copy
C:\Program Files\ArcGIS\Earth\bin\automation\settings.json to
C:\\Users\\<user.name>\\Documents\\ArcGISEarth\\automation\\settings.json
Modify the autostart setting to true, it is false by default.
Install dir file.
"version": "1.12",
"autoStart": false,
"baseUrl": "http://localhost:8000"
After copy to user dir
"version": "1.12",
"autoStart": true,
Pain in the **bleep**!!!
Hi @BillSmith
Thanks for your feedback.
Currently, our default setting is true and supports editing the settings.json in <user.name>\Documents\ArcGISEarth\automation.
We have logged your great suggestions and will improve this in the following releases. We will also keep you updated.
Lexie
