ArcGIS Earth and Portal
795
04-07-2023 09:00 AM
freza0
Anyone ever run into a situation where you can’t connect to your Portal through ArcGIS Earth? It keeps telling me to make sure its running and the url is correct... both of which are true. Can connect via web browser and ArcGIS Pro without issue. Enterprise v10.6 and Earth 10.9
BillFox
MVP Notable Contributor
Earth 10.9?
jsphillips
Hello @freza0. Are you attempting to login to your Portal via IP? The recommended method is to use the web adapter url.
John Phillips | Product Manager ArcGIS Earth
Esri | jphillips@esri.com | T 757 575 0786
