Drawing a new point, the placemark's <hotSpot> (anchor point) will always be at the bottom center. It makes sense if you use a pin icon:
But it feels awkward when you use a target icon:
It would be nice to be able to adjust the icon anchor point directly at the creation of the point.
Thank you.
I'm glad to share that the `<hotSpot>` / anchor point property will be supported in ArcGIS Earth V2.3. You'll be able to select presets or specify the anchor position. Please keep tuned on the next version.
Thanks.
Sharon
Thank you @Sharon_MU !
This feature is supported in the upcoming December release.
Hello @jsphillips
I tested this feature with the 2.3 beta release. It is great to be able to change the anchor point within ArcGIS Earth! But there is an issue :
The default anchor point position is at the center (X:0,5 ; Y:0,5)
But the default point icon is a blue pin. So the combination of these 2 is odd :
The default combination should be :
