ArcGIS Earth 1.11 has been released on Oct. 1. To learn more, and to download ArcGIS Earth, see the ArcGIS Earth overview or Microsoft store.
This release includes new 3D capabilities, supports for new data types, and user experience enhancements. Here are a few highlights:
Sunlight and shadows: You can layer dynamic sunlight and shadows on scenes that can be labeled with the time and date, in any time zone.
Underground navigation: Go underground or under the sea with new subsurface navigation tools.
New data support: Expand your workflows by adding GPX, WFS, and GeoJSON to your ArcGIS Earth workspace.
Updated bookmarks: Create and manage multiple bookmark groups and add more context to your bookmarks with customizable informational pop-ups.
Symbology: Start using the new symbol types: Type (Unique Symbol) and Counts and Amounts (Colors).
Please see the below key fixes that are included in this release.
Features | Description |
Daylight | Shadow on terrain is not supported in ArcGIS Earth. |
Daylight | Daylight animation with shadow effect will not function well if you lock/unlock screen or change screen display during daylight analysis process. |
Underground mode | Camera control might get sensitive while navigating data under the ground. |
Underground mode | There might be gaps on the basemap after enabling underground mode. |
Underground mode | With Atmosphere effect on, changing ground transparency might cause rendering issue. |
Symbology | If the feature layer is from a portal item or inside a group, adjusted symbology will be cleared once you exit ArcGIS Earth. |
