processed image quality is not as good as the raw imagery
478
09-06-2018 07:31 AM
BillLotz
Occasional Contributor II
After processing the imagery is "fuzzy" and not as sharp as the raw imagery.
I have adjusted the processing parameters but have not had much improvement in the processed image quality.
DanPatterson_Retired
Bill
screen grabs?
can you show what and where you made adjustments?
BillLotz
Dan,
I used the default 2d template (not rapid). I have played around with the 2d options, Resolution, Merge tiles, Big TIFF.
JamesTaylor3
Are you processing using the Rapid or 2D Project Template?  The Rapid Project Template will produce products with a lower resolution, it is designed to do quick low resolution processing.
