It would also be nice if user could add more than one folder when selecting the photos for a project. Sometimes a flight has to be broken up into several collections, this can then result in photos having the same names, and for that reason they are stored in separate folders. Having this capability would allow less messing around on the analyst side for file prep and such.
We have added in the ability to select and import multiple folders through the Add Folder button in Drone2Map 2023.2. You can also drag multiple folders into the New Project window table and they will be imported together. Which is already supported in 2023.1.x: https://docdev.arcgis.com/en/drone2map/2023.1/get-started/whats-new.htm#ESRI_SECTION1_F13A3F359C0049...
This has been implemented
