FDO error: -2147024893
2562
11-22-2017 10:49 AM
JimBirch
I recently received an upgrade to my PC and am running Windows 10 Enterprise 64 bit. It apparently is fully compatible with ArcGIS 10.3.1, so it should not be an issue.
I am frequently losing data connections with data that is stored in a filedatabase. The featureclass is not affected in any way, other than losing edits. When I restart the featurclass is there, I just have to repeat my edits. This will happen many times throughout the day and is very frustrating.
It is not a network issue as the network is always available and unaffected. It also does not appear to affect data from the SDE. Only data in a filedatabse.
Has anyone else experienced this problem and if so what was the resolve?
Thank you
PeteSmyth1
Hi @JimBirch
I got this error this morning, and I feel it has something to do with either the length of the filepath or the characters in the filepath.  The FGDB I was trying to use was buried very deep in the file system.  When I copied the FGDB locally to a very simple filepath I did not get the error anymore.
HTH
Pete
