Checking if ArcGIS extension has already been checked out manually using ArcPy
551
11-06-2020 07:28 AM
LuizaCintra_Fernandes
Hello,
I have to map if a user uses some ArcMap extention in the day. I figured out a script that checks if the extention is working or not, by testing each one and reading the error message. These script works fine if I run it inside arcmap, but as standalone script it isn't working.
Is there anyway that I can do it as standalone script? Or any other way to checked if these extensions are checked out?
Or I can schedule a script inside arcmap to run everytime users started it or close?
My script is bellow:
#class to check extentions
class lista_ext():
#initialize the list
def __init__(self):
self.l=[]
#get list values
def getlist(self):
return self.l
Test if the extension is turned on.
If there error given is different from '000824',
this mean that the extension is on and tried to exceute
def testarextension(self,e,name):
if str(e).find('000824') ==-1:
self.l.append(name)
return self.l
def testarfuncoes(self):
Test one function from each extension.
The function chosen it's not supposed to work and will show an error message anyway
try:
arcpy.Idw_3d(1)
except Exception:
e = sys.exc_info()[1]
self.testarextension(e,'3D Analyst')
try:
arcpy.IDW_ga(1)
except Exception:
self.testarextension(e,'Geostatistical Analyst')
try:
arcpy.Solve_na(1)
except Exception:
self.testarextension(e,'Network Analyst')
try:
arcpy.UpdateDiagram_schematics(1)
except Exception:
self.testarextension(e,'Schematics')
try:
arcpy.sa.Int('1.1')
except Exception:
self.testarextension(e,'Spatial Analyst')
try:
arcpy.TrackIntervalsToFeature_ta(1)
except Exception:
self.testarextension(e,'Tracking Analyst')
return self.l
