Arcmap has stopped working 10.4
4880
5
02-25-2016 03:02 PM
StuartBayly
Hello there
I have found a small problem when installing ArcGis 10.4,   f
or some reason after I installed ArcMap ,  the start-up would display  “ Arcmap has stopped working “
However,  I found ArcGIS would only open once I had uninstalled the Data Interoperability extension 10.2
Tags (3)
XanderBakker
Esri Esteemed Contributor
I can imagine that using different versions of different ArcGIS components that this could cause this failure. Any reason why you updated ArcGIS to 10.4 but left DataInterop on 10.2?
StuartBayly
Hello Xander
Yes, well I had actually forgotten I had it installed. Just that the error message was pretty vague
Cheers
Stuart Bayly
Spatial Analyst
Location, Intelligence & Integration Services
Pakihi Hangarau Kōrero | Business and Information Technology
Te Kaunihera o Pōneke | Wellington City Council
P 04 803 8253 | M 021 227 8253
E Stuart.Bayly@wcc.govt.nz<mailto:Stuart.Bayly@wcc.govt.nz> | W Wellington.govt.nz<http://wellington.govt.nz/>
Have you visited our Open Data Portal yet? http://data.wcc.opendata.arcgis.com/
The information contained in this email is privileged and confidential and intended for the addressee only.
If you are not the intended recipient, you are asked to respect that confidentiality and not disclose, copy or make use of its contents.
If received in error you are asked to destroy this email and contact the sender immediately. Your assistance is appreciated.
<http://wellington.govt.nz/wcc-email-campaign>
DanPatterson_Retired
Existing ArcGIS for Desktop users—Help | ArcGIS for Desktop
Check the details there, to ensure that you have completed all the other requirements.  I suspect the license manager may have been in play.
BrittaSchroeder
@Stuart Bayly, see this thread: https://community.esri.com/thread/173270
My ArcGIS License is confirmed 10.4, but after installing both ArcGIS Desktop 10.4 and the Data Interoperability extension 10.4, ArcMap failed to open on two separate Windows 7 SP1 machines. I uninstalled the Data Interoperability extension and repaired the Desktop install, and ArcMap was once again able to open and function properly.
LaureneKoman
What else is installed on these 2 machines where you can repro this?  We've tested this on numerous machines and can not reproduce the ArcMap failure with Data Interop installed.   Any other details would be helpful.  thanks!
Laurene Koman
ArcGIS Installation Team
