ArcGIS Trial version - Geostatistical Analyst extension (Tool Not Licensed)??
4932
16
03-07-2016 08:04 PM
RE
New Contributor III
Dear All,
I just installed a Trial Version of ArcGIS. I was able to authorize it using the authorization code provided by ESRI. However, I could not use Geostatistical Analyst extension because it says 'Tool Not Licensed'. My question is do I need to purchase the license? I thought it is a free trial version. And the extension has been 'installed' and 'authorized' as per ArcGIS Administrator. Your help/thoughts will be greatly appreciated.
Thanks
R E
RE
New Contributor III
Yes, I already tried to re-authorize. It said 'All requested features have already been authorized on this machine'.
RE
New Contributor III
Despite these authorizations, All extensions don't work.
I don't know what's the problem.
I tried to contact ESRI but haven't got a reply yet.
JayantaPoddar
MVP Esteemed Contributor
The culprit could be the trusted storage. You need to delete the trusted storage. If it's a 60-days ArcGIS trial you are using, then you should be able to authorize it again.
Please follow these steps:
1. Close all ArcGIS Applications.
2. In Windows Explorer, navigate to C:\ProgramData\FLEXnet. Delete all the files in it.
3. Authorize ArcGIS Advanced (Single Use) license using the same EVA********* code.
Check if the licenses are working now.
Think Location
RE
New Contributor III
Hi Jayanta, Thanks again. But could you please elaborate more where to find the FLEXnet folder. I don't have this directory C:\ProgramData\FLEXnet.
What I have is C:\Program Files or C:\Program Files (x86)
Thanks
RE
New Contributor III
I found it. I deleted the files. I re-authorized ArcGIS. But still the extensions do not work.
DanPatterson_Retired
so you reauthorized, they show up as available extensions in the Customize, Extensions menu and they don't appear? or you didn't toggle them on?
RE
New Contributor III
Thank you all for your comments and suggestions.
My problem has been solved.
I don't know what caused the problem, but what I did was nothing extraordinary.
I shut down everything, restarted the pc, reauthorized, enabled all extensions (failed), disabled all extensions, restarted Arcmap, enabled all extensions - finally!
Cheers
