I upgraded from 10.4 to 10.5 and find the text sizes all over the place, especially in the table of contents. I did not uninstall 10.4 before installing 10.5. Could that be the reason? The top toolbar also has very large text compared to the old 10.4. This is very disconcerting.
check your operating system font scaling, you might have it set too high
From your desktop, right-click and select Display Properties,,, check in there
Thanks. I changed the display to medium. For some reason it was on large.
Dr. Linda Tomaselli, GISRDC
341 Jamaica Way
Niceville, FL 32578
(850) 687-6459 or (850) 897-2012
<mailto:Ltomaselli@GISRDC.com> Ltomaselli@GISRDC.com or <mailto:Ltomaselli@Earthlink.net> Ltomaselli@Earthlink.net
I forgot to say, it also corrected the overly sensitive drop downs for the top row of selections. ???? But it worked.
Thanks again.
341 Jamaica Way
Niceville, FL 32578
Glad it worked out
The issue could have been caused due to the current Windows theme. Try changing the Windows theme to Basic.
Thank You.
I changed the display propertied to medium. It worked!
341 Jamaica Way
Niceville, FL 32578
It also corrected the overly sensitive drop downs for the top row of selections. ???? But it worked.
Thanks again.
