We're experiencing failure of tools in the Spatial Statistics toolbox, on all machines. Checked our ENV paths, did a reinstall, etc... nothing seems to fix it. Here is the error we get.
Executing: SpatialAutocorrelation places POP2000 NO_REPORT INVERSE_DISTANCE EUCLIDEAN_DISTANCE NONE # #
Start Time: Thu Dec 08 10:31:01 2016
Running script SpatialAutocorrelation...
Failed script SpatialAutocorrelation...
File "c:\program files (x86)\arcgis\desktop10.4\ArcToolbox\Scripts\MoransI.py", line 16, in <module>
import SSUtilities as UTILS
File "c:\program files (x86)\arcgis\desktop10.4\ArcToolbox\Scripts\SSUtilities.py", line 29, in <module>
import matplotlib.path as PATH
File "C:\Python27\ArcGIS10.4\lib\site-packages\matplotlib\__init__.py", line 169, in <module>
from urllib2 import urlopen
File "C:\Python27\ArcGIS10.3\Lib\urllib2.py", line 94, in <module>
File "C:\Python27\ArcGIS10.3\Lib\httplib.py", line 71, in <module>
File "C:\Python27\ArcGIS10.3\Lib\socket.py", line 68, in <module>
ImportError: cannot import name RAND_egd
Failed to execute (SpatialAutocorrelation).
Failed at Thu Dec 08 10:31:01 2016 (Elapsed Time: 0.05 seconds)
The RAND_egd failure seems to be the common thread for all the tools. Interestingly, when you launch the Optimized Hot Spot Analysis tool, you get the error immediately, as the red X next to the 'Input Features' parameter. When you click on the red X, you get this:
updateParameters Syntax Error: Runtime error Traceback (most recent call last): File "c:\program files (x86)\arcgis\desktop10.4\ArcToolbox\Toolboxes\Spatial Statistics Tools.tbx#OptimizedHotSpotAnalysis_stats.UpdateParameters.py", line 6, in File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcToolBox\Scripts\SSUtilities.py", line 29, in import matplotlib.path as PATH File "C:\Python27\ArcGIS10.4\lib\site-packages\matplotlib\__init__.py", line 169, in from urllib2 import urlopen File "C:\Python27\ArcGIS10.3\Lib\urllib2.py", line 94, in File "C:\Python27\ArcGIS10.3\Lib\httplib.py", line 71, in File "C:\Python27\ArcGIS10.3\Lib\socket.py", line 68, in ImportError: cannot import name RAND_egd
Anyone see anything obvious?
Stace
