Newly installed Desktop won't run
5005
10
05-09-2016 06:53 AM
JeffreyDege
I'm trying to get Arc Map 10.4 running, from a new installation of ArcGIS_Desktop on Windows 10.
I'd initially installed the free trial, then uninstalled, and installed ArcGIS_Desktop_104_149411.exe.
The installation worked fine, and the Authorization Wizard seems to have worked. I see EDN ArcGIS for Desktop Basic listed in ArcGIS Administrator, with version 10.1-10.4, marked as Installed, and Authorized, with an expiration of 01-Dec-2016.
But when I run ArcMap 10.4, I get a splash screen showing the message "Loading Document..." for about 30 seconds, then it goes away.
I filed a support ticket with ESRI last week, but have had no response.
Is there some sort of log that ArcMap might be writing to, that would give me a hint as to what is going wrong?
I've tried un-installing, and re-installing, and it's made no difference.
curtvprice
MVP Alum
45924 - ArcMap crashes during Loading Document launch stage
My policy is unless I have a really good specific reason to update, I use Esri's shipped Python versions. Better safe than sorry.
