ArcMap 10.6 Install Problems
3842
13
07-02-2018 12:26 PM
TimothyHuggins
New Contributor II
I installed ArcMap 10.6 on a new desktop and when I try to open the program the windows installer box pops up and says preparing to install. Then nothing happens.
Any ideas?
George_Thompson
Esri Frequent Contributor
Are you running the installer as an Administrator or with an account with the needed permissions to install software?
Does the machine meet the minimum ArcGIS Desktop 10.6 system requirements—System Requirements | ArcGIS Desktop ?
Is it possible that your anti-virus is interacting with the installation?
--- George T.
TimothyHuggins
New Contributor II
Yes my account is an administrator account.
Yes it far exceeds the minimum system requirements.
The computer came with only windows defender antivirus. I tried turning that off and it still did the same thing.
Attached is a screen shot of the message.
George_Thompson
How long have you left it at that screen?
--- George T.
TimothyHuggins
New Contributor II
maybe 10 minutes.
Should I try letting it go longer?
LaureneKoman
Occasional Contributor III
Cancel out of the setup dialog.
Follow these instructions to enable MSI logging.  https://support.microsoft.com/en-us/help/223300/how-to-enable-windows-installer-logging
Start ArcMap again.
there will be a randomly named MSI log in your %temp% folder.  Send me  (or post) that log file, this will help us identify which resource the setup is trying to install or repair.
Thanks
Laurene Koman
TimothyHuggins
New Contributor II
HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\Installer
I can get all the way to policies\software\microsoft\windows\ but do not see "installer".
LaureneKoman
You can add that key and then the remainder.
TimothyHuggins
New Contributor II
Is this the right thing?
LaureneKoman
Thanks. The log shows that this setup/product is attempting to repair itself.
MSI (s) (90:40) [15:59:05:696]: Product: TerraGo Publisher for ArcGIS -- Configuration failed.
MSI (s) (90:40) [15:59:05:696]: Windows Installer reconfigured the product. Product Name: TerraGo Publisher for ArcGIS. Product Version: 6.0.03092. Product Language: 1033. Manufacturer: TerraGo Technologies. Reconfiguration success or error status: 1602.
