Missing point in the map but not in the table
620
10-24-2016 08:07 AM
CamilaNeder
Hello community!
I am working with Arcmap 10.4.1. I made a shapefile with point values using the Arctools, define projection too, I can see them all in the table but just 3 of them I cannot see it in the map (not symbol appearing). When I edit the feature and select the row where it's my data missing value, I can sea a cross, so makes me think that the XY it's corrected identify but for some reason I still without seeing the point.
Any clue of what it's happening or how I can correct this?
Thanks!!!!!
Camila
Tags (1)
CamilaNeder
Ok... finally I figure out! It was a clipping problem. Some shapefiles were clipped so I couldn't see the points, instead of others that weren't  and I could see them.
