The Defense Mapping license has been checked out in ArcGIS Administrator, but it does not display in the ArcMap toolbars / extensions. How do I find?
Hi Haley,
Thank you for your question.
If you launch ArcMap and go Customize->Extensions... and on the Extensions dialog you do not see an extension called Defense Mapping, then Defense Mapping has not been installed. Defense Mapping, along with Airports, Aviation Charting, Data Reviewer, Maritime Bathymetry, Maritime Charting, and Production Mapping are software components (i.e. extensions) that are available through the Mapping and Charting Solutions (MCS) Desktop installer.
MCS has its own licensing and its own install. Do you have access to the Mapping and Charting Solutions Desktop installer? If you have access to the Mapping and Charting Solutions (MCS) Desktop installer, in the Product Selection of the installer wizard, select Defense Mapping. After you have installed the software, launch ArcMap and go Customize->Extensions... and on the Extensions dialog you will see three extensions appear: Data Reviewer, Defense Mapping, and Production Mapping.
Regards,
Dan
Hi Haley,
Regards,
Dan
Thank you Dan!
You are welcome Haley!
