Workspace or data source is read only - Data Reviewer for Server
1683
05-25-2018 12:59 PM
PrasanthRamachandran2
New Contributor II
I have configured "Report Feature" widget in web app builder using our newly configured Data Reviewer for server services. Everything works fines however when I try to save an "Visual reviewer Error" using Report Feature widget, I am receiving below error message.
Error Message on Web App:
Error writing record (Reviewer.RevTableWriter.1):Problem inserting row into table (Reviewer.RevTable.1):Error flushing row insert (Reviewer.RevTable.1):Error flushing row insert (Esri GeoDatabase):Workspace or data source is read only.
NOTE :
ArcGIS Server account (which is used to run the ArcGIS for Server windows service) has FULL CONTROL on the folder and file geodatabase (Data Reviewer workspace).
Reply
JayCary
Sounds like you are using a file geodatabase with your service. If so, the only operations that are supported are those which read from the workspace (such as dashboard and get results). You'll want to use an enterprise geodatabase for operations that create/write results. Here is a link to documentation that describes this limitation.
JayCary
New Contributor II
Thank you. It was very helpful.
Reply
