Why Data Reviewer Server Services fail to start after upgrade?
435
02-25-2020 09:00 AM
MarceloMarques
I have upgrade ArcGIS Server and Data Reviewer Server (DRS) binaries. ArcGIS Server is working fine but DRS services fail to start. What is the cause?
Service failed to start
BatchValidation.reviewer.MapServer:
Could not load file or assembly 'ESRI.Reviewer.Public.Engine.Interop, Version=10.6.0.0, Culture=neutral, PublicKeyToken=49f88df635890024' or one of its dependencies. The system cannot find the file specified.
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
MarceloMarques
Resolution: Reinstall DRS binaries and redeploy DRS SOE, must do this step to install the new SOE manually.
Open ArcGIS Server Manager > Site > Extensions > ESRI.ReviewerServer.soe > Action: Edit >
Extension > Select File >
"C:\Program Files\ArcGIS\ArcGISDataReviewerServer\Server10.8\Bin\ESRI.ReviewerServer.soe"
Then, test each ArcGIS Server Service, stop/start each service manually and check the ArcGIS Server Logs for severe errors.
If necessary redeploy DRS Services.
https://enterprise.arcgis.com/en/data-reviewer/latest/help/publishing-arcgis-data-reviewer-for-server-services.htm
If necessary reconfigure DRS Services using DRS Configuration Utility, see example below.
1. ArcGIS Server DRS Services > BatchValidation > reviewer
Open the DRS Configuration Utility:
Connect to ArcGIS Server:
http://localhost:6080/arcgis/admin
UserName: drsadmin
Password: ****
Add DRS extension:
Select extension file
Set Reviewer Workspace:
Select Map Service - BatchValidation/reviewer.MapServer
Select New Reviewer Workspace - F:\sqlexpressgdb\localhost_RevWorkspace.sde
MarceloMarques
UserName: drsadmin
Password: ****
Add DRS extension:
