Using Data Reviewer to find Points not connected to Polylines.
1459
03-25-2020 03:42 PM
brycehoward
Feature Type: Simple Junction
Geometry Type: Point
Some times these electrical junctions are left behind and are just floating in the middle of nowhere. What checks can I do within data reviewer to find nodes that are not touching or are connected to any polylines?
Tags (1)
KumarGaurav
Hi Bryce,
You can use Geometry on Geometry check with "Touches" as spatial relation and use "Not" option. Use Point as Feature class 1 and Line as Feature class 2.
For more info about this check please refer to the following web help topic:
Finding geometries with spatial relationships—Help | Documentation
Kumar
KumarGaurav
Hi Bryce,
Kumar
brycehoward
Thank you so much! I added“Geometry on Geometry Check” for each polyline with "Touches" as spatial relation and use "Not" option   with in the Composite check tool. Works almost perfectly!
