use of Regular Expressions in Data reviewer checks?
3969
7
05-22-2012 04:19 AM
MartinHvidberg
Dear Forum
I???m trying to use Data Reviewer to catch invalid dates in a string (TEXT) field.
I use the "Regular Expression Check Properties" in "Table Checks".
My field holds date values of form YYYYMMDD, e.g. 19660313
I tried to write a Regular Expression to fit this, some thing like:
([0-9][0-9][0-9][0-9])(0[1-9]|1[0-2])(0[1-9]|[12][0-9]|3[01])
But Data Reviewer keeps returning all records as errors, so obviously I???m doing something wrong.
Can anyone help me to a good R.E. expression, which would identify only the dates that do not match the YYYYMMDD format?
Best regards
Martin
MichelleJohnson
Hello Martin,
Have you seen the example in the help documentation?
Try this: ((19)|(20))\d\d((0[1-9])|(1[012]))((0[1-9])|([12][0-9])|(3[01]))
I think you were missing a couple of sets of parenthesis.
MichelleJohnson
Hello Martin,
TuanVu_Huu
New Contributor II
Dear Michelle,
I am Tuan from Esri Vietnam.
I am help customer in vietnam to build table check and I using Regular Expression check. I have try to check value field name of map sheet as like this : 6636-V-DN
And I have try expression as :
([0-9][0-9][0-9][0-9])\-([A-Z])\-([A-Z][A-Z])
But it is not return the error.
Moreover, when I have set some expression for other field it is work but it not check for NULL or Space value?
Please help!
Many thank in advance!
Vu Tuan
TuanVu_Huu
New Contributor II
Dear Michelle,
sorry I mean I have typed expression as: 6636-V-DN
([0-9][0-9][0-9][0-9]-\[A-Z]-\[A-Z][A-Z])  too
But still not get error.
many thanks,
Vu Tuan
MichelleJohnson
Vu Tuan,
There is an option to check for NULLs.  It will not flag fields with blanks.  But I think that the expression should flag those.  If it does not, then you can create an Execute SQL Check to look for NULL and blanks.
Regards,
michellej.
TuanVu_Huu
New Contributor II
Dear Michelle,
I have added some option, But still fail.
([0-9][0-9][0-9][0-9]\-\[A-Z]\-\[A-Z][A-Z])
([0-9][0-9][0-9][0-9]-[A-Z]-[A-Z][A-Z])
Please advice
Vũ Tuấn
MichelleJohnson
Hello Vu Tuan,
I used the last option you provided, ([0-9][0-9][0-9][0-9]-[A-Z]-[A-Z][A-Z]), and I was getting expected results.  I'm assuming that your format must be like 6636-V-DN.
I created sample data with good and bad formatting.  The highlighted records were returned.  They do not follow format of 4 digits, dash, 1 capital letter, dash, 2 capital letters.
Regards,
michellej.
MartinHvidberg
Thanks Michelle
Your RE. is perfect, thanks for that.
Also thanks for the link.
🙂 Martin
