Has the Geodatabase Schema Compare being deprecated?
1451
10-18-2017 05:02 PM
GregCocks2
New Contributor II
Has the Geodatabase Schema Compare being deprecated in Data Reviewer?
I can't see in in the tools or in ArcPy.
I have the Data Reviewer extension licence. (ArcGis Pro 2.0 and ArcGIS Desktop 10.5)
Thanks in advance!
deleted-user-rmQdIupSdOqe
New Contributor III
I just checked and it is still in there. I am in v. 10.5.1
GregCocks2
New Contributor II
Ann, thank you...
I am looking in ArcGIS Pro - and see all in the Toolbox except this...
data Reviewer tool box screen shot in ArcGIS Pro 2.x
I am using Geodatabase Schema Compare—Help | ArcGIS for Desktop  as a reference...
Further, the code call arcpy.SchemaCompare_Reviewer() says "AttributeError: module 'arcpy' has no attribute 'SchemaCompare_Reviewer'"
(which is consistent, as the IntelliSense is not seeing it IDE.. although it sees the other Date Reviewer attributes...)
Hmmmmmmmmmmmmmmmmmmmm.........
I will have IT install it on my ArcGIS Desktop 10.5 and try there...
Thank you!
StephanieLong1
New Contributor III
Did you ever get an answer to this?  I am experiencing the same exact issue.
GregCocks2
New Contributor II
Sorry for the delay in replying...
No luck I am afraid...
by Anonymous User
Not applicable
When will this functionality be implemented in Pro. Just curious, what was the rational for not inculding this data reviewer pro?
