Geometry on Geometry to find duplicate address ranges that touch
735
08-21-2018 06:45 AM
JulieRoebotham
I feel like this is simple AND i've done it before.. the batch file for DR address management seems to have lost its SQLs for geometry on geometry, as have my own personal .rbj files leading me to believe i'm losing my mind!!!!!!
So - is there a way to use the Geometry on Geometry check to find segments that touch but have the same FROM_LEFT and TO_LEFT / FROM_RIGHT and TO_RIGHT? (essentially duplicate address ranges like one might get after batch splitting segments and NOT prorating addresses  )
THANKS!
JulieRoebotham
Sometimes I'm right in that I HAVE done this easily in the past and i HAVE lost my mind.. sigh
the very technical 'scroll down on the check' reveals that you can set the error condition to search for duplicates just a little farther down In the dialog. totally OOTB, no thinking required
JakeSkinner
Esri Esteemed Contributor
Hi Julie,
Will the Find Identical tool work for you?
Find Identical—Data Management toolbox | ArcGIS Desktop
JulieRoebotham
JayCary
Hey Julie,
Here's the check UI in ArcGIS Pro...
ArcGIS Data Reviewer
Better?  Worse?!?!
Thanks for the feedback!
