I am running the following:
- Windows XP SP3
- ArcGIS 10 Desktop SP4 Build 4000
- Esri Production Mapping SP4 Build 1125
I am using the TemplateData.gdb located at C:\<ArcGIS Install Location>\Desktop10.0\TemplateData\TemplateData.gdb\USA
The TemplateData.gdb is also my Reviewer workspace.
I launch ArcMap and open a brand new Untitled.mxd. I add the cities and counties feature classes to ArcMap. I specify the TemplateData.gdb as my Reviewer workspace and I create a Reviewer Session called Test1. I then do the following:
1. On the Data Reviewer toolbar, I click Reviewer Table. The Reviewer Table window is launched and is empty.
2. I select U.S. Cities with OBJECTID = 1, 3, 4, 3150, and 3151.
3. On the Data Reviewer toolbar, I click Browse Features. On the Browse Features dialog, I click Write All. On the Commit To Reviewer Table dialog, I click Delete Feature and then click OK. Five records are written to the Reviewer Table. I close the Browse Features dialog.
4. On the Production Editing toolbar, I click Production Start Editing.
5. I select U.S. Counties with OBJECTID = 28 and through the Update Attributes window I change the NAME = Lampley and click Apply.
6. I select U.S. Cities with OBJECTID = 10, 11, 12, and 3152 and delete the features.
7. On the Production Editing toolbar, I click Save Edits.
8. I select U.S. Cities with OBJECTID = 13, 15, and 16.
9. On the Data Reviewer toolbar, I click Browse Features. On the Browse Features dialog, I click Write All. On the Commit To Reviewer Table dialog, I click Delete Feature and then click OK. Three records are written to the Reviewer Table. I close the Browse Features dialog.
10. On the Production Editing toolbar, I click Stop Editing. I am asked 'Do you want to save your edits?', I click Yes.
I am not able to reproduce your issue based on the information you have provided to me. Please use the TemplateData.gdb and provide me with detailed steps to reproduce your issue. Your steps should indicate how you are committing the errors to the Reviewer Table (e.g. through Browse Features, Commit to Reviewer Table, Individual Check, or RBJ).
